[postgis-users] shp2pgsql - how to avoid double quotes around table name and column names
cyw at dls.net cyw at dls.net
Thu Sep 4 15:37:33 PDT 2008
Hi All,
The shp2pgsql generated sql uses double quotes around table name and column names, such as:
    CREATE TABLE "x" (gid serial PRIMARY KEY, "route" varchar, "jurisdicti" varchar,....
The effect is that I have to use double quotes in SQLs that access data  in this table later on. For example, I have to use sql like:
    select * from "x"
Sql without double quotes, such as below, won't work:
    select * from x
Thanks for any help.
cyw
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080904/b109275d/attachment.html>
