[postgis-users] CleanGeometry plpgsql function
Dane Springmeyer
blake at hailmail.net
Thu Sep 4 19:08:50 PDT 2008
Hi David,
I grabbed a copy previously and here it is:
-- $Id: cleanGeometry.sql 2008-04-24 10:30Z Dr. Horst Duester $
-- cleanGeometry - remove self- and ring-selfintersections from
-- input Polygon geometries
-- http://www.sogis.ch
-- Copyright 2008 SO!GIS Koordination, Kanton Solothurn, Switzerland
-- Version 1.0
-- contact: horst dot duester at bd dot so dot ch
-- This is free software; you can redistribute and/or modify it under
-- the terms of the GNU General Public Licence. See the COPYING file.
-- This software is without any warrenty and you use it at your own risk
CREATE OR REPLACE FUNCTION cleanGeometry(geometry)
RETURNS geometry AS
$BODY$DECLARE
inGeom ALIAS for $1;
outGeom geometry;
tmpLinestring geometry;
tmpPolygon geometry;
Pk geometry;
Pi geometry;
nGeometries integer;
nGeom integer;
intRingPi geometry;
nIntRings integer;
extRingPk geometry;
isHole boolean;
Begin
outGeom := NULL;
-- Clean Process for Polygon
IF (GeometryType(inGeom) = 'POLYGON' OR GeometryType(inGeom) =
'MULTIPOLYGON') THEN
-- Only process if geometry is not valid,
-- otherwise put out without change
if not isValid(inGeom) THEN
-- create nodes at all self-intersecting lines by union the polygon
boundaries
-- with the startingpoint of the boundary.
tmpLinestring :=
st_union(st_multi(st_boundary(inGeom)),st_pointn(boundary(inGeom),1));
outGeom = buildarea(tmpLinestring);
RETURN st_multi(outGeom);
else
RETURN st_multi(inGeom);
END IF;
-- Clean Process for LINESTRINGS, self-intersecting parts of
linestrings
-- will be divided into multiparts of the mentioned linestring
ELSIF (GeometryType(inGeom) = 'LINESTRING' OR GeometryType(inGeom)
= 'MULTILINESTRING') THEN
-- create nodes at all self-intersecting lines by union the linestrings
-- with the startingpoint of the linestring.
outGeom := st_union(st_multi(inGeom),st_pointn(inGeom,1));
RETURN outGeom;
ELSE
RAISE EXCEPTION 'The input type % is not
supported',GeometryType(inGeom);
END IF;
End;$BODY$
LANGUAGE 'plpgsql' VOLATILE;
On Sep 4, 2008, at 6:51 PM, David Jantzen wrote:
> Does anyone have a definition of cleanGeometry that they could post?
> The wiki page at
> http://postgis.refractions.net/support/wiki/index.php?full=geometry
> references the following unresponsive link:
> http://www.sogis1.so.ch/sogis/dl/postgis/cleanGeometry.sql
> Thanks,
> David
> postgis-users mailing list
