[postgis-users] shp2pgsql - how to avoid double quotes aroundtable name and column names
cyw at dls.net cyw at dls.net
Thu Sep 4 21:09:50 PDT 2008
Thanks. The problem was that one of my table use a PostgreSQL keyword.
----- Original Message -----
From: "Kevin Neufeld" <kneufeld at refractions.net>
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Sent: Thursday, September 04, 2008 9:41 PM
Subject: Re: [postgis-users] shp2pgsql - how to avoid double quotes
> You should only have to reference your table with double quotes if your
> table name contains uppercase characters or is a PostgreSQL keyword. In
> PostgreSQL, this works, so using double quotes is not a problem:
> CREATE TABLE "x"(gid serial);
> SELECT * FROM x;
> What is your exact command with shp2pgsql?
> -- Kevin
> cyw at dls.net wrote:
>> Hi All,
>>  The shp2pgsql generated sql uses double quotes around table name and
>> column names, such as:
>>  CREATE TABLE "x" (gid serial PRIMARY KEY, "route" varchar, "jurisdicti"
>> varchar,....
>>  The effect is that I have to use double quotes in SQLs that access data
>> in this table later on. For example, I have to use sql like:
>>  select * from "x"
>>  Sql without double quotes, such as below, won't work:
>>     select * from x
>>  Thanks for any help.
>>  cyw
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
