[postgis-users] WGS84 to meters
Bruce Raup
brauplists at gmail.com
Mon Sep 8 18:56:55 PDT 2008
If your data are globally distributed (as you said they are), then UTM
probably isn't the best choice. A global equal-area projection would
be better, in that you can use the same parameters regardless of where
on the globe you're working. I have a similar application, and use
Cylindrical Equal Area. I use something like (with an old version of
PostGIS -- I think the function names all start with ST_ now):
select sum(area(transform(glacier_polys,32767))) FROM glacier_polygons ...
Note that the EPSG code here is one I defined. I think the current
version of PostGIS might have CEA projection defined in some proper
location.
Bruce
On Mon, Sep 8, 2008 at 7:36 PM, Robert Coup
<robert.coup at onetrackmind.co.nz> wrote:
> On Tue, Sep 9, 2008 at 3:14 AM, Nicolas Ribot <nicky666 at gmail.com> wrote:
>> No for surfaces. You will have to project your data into a planar
>> projection system to do so (UTM for instance). This thread may be
>> useful in your case to find the correct UTM zone according to your
>> objects coordinates:
> Untrue, the maths is just a little harder! And you need to assume the globe
> is a sphere (ala distance_sphere()):
> If you're dealing with lat-lon "rectangles" you want something like this:
> http://mathforum.org/dr.math/faq/formulas/faq.sphere.html#spherecap
> If you're dealing with arbitrary polygons its a bit more complicated:
> http://groups.google.com/group/comp.infosystems.gis/browse_frm/thread/af0401d07c3068b5?lnk=igtc
> HTH,
> Rob :)
> postgis-users mailing list
Bruce Raup
http://cires.colorado.edu/~braup/
