[postgis-users] why specify spheroid?
Paragon Corporation
lr at pcorp.us
Tue Sep 9 05:33:54 PDT 2008
Willy,
Not that newbie of a question. Actually its probably not obvious but
distance_sphere and distance_spheroid don't even look at the srid of the
geometry fed to them. If you give it a non-long lat coordinates you will
also get garbage results as I recall.
So they always assume point and point is long lat.
Hope that helps,
Regina
_____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Willy-Bas Loos
Sent: Tuesday, September 09, 2008 5:48 AM
To: PostGIS Users Discussion
Subject: [postgis-users] why specify spheroid?
(This probably will score me some noob-points, but whatever. Actually i
might loose a few if i get to understand this.)
Why do distance_spheroid et al. require that you specify the spheroid?
Doesn't the srid provide enough information?
cheers,
WBL
"Patriotism is the conviction that your country is superior to all others
because you were born in it." - George Bernard Shaw
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080909/39e61c7b/attachment.html>
