[postgis-users] why specify spheroid?
Obe, Regina
robe.dnd at cityofboston.gov
Tue Sep 9 07:07:13 PDT 2008
The srid of the geometry the identifier in the spatial_reference_sys
table that defines the datum, coordinates of your geometry etc of the
geometry in question). Spatial reference system of the geometry. If
your st_srid(the_geom) = -1 and you fed it to
distance_sphere/distance_spheroid, it wouldn't matter as long as your
coordinates are actually measured along the ellipsoid you specify (or
approximate ellipsoid of distance_sphere).
The distance_sphere never takes a spheroid as I recall - and always
assumes a sphere and is faster than spheriod but less accurate.
Hope that helps,
Regina
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Willy-Bas Loos
Sent: Tuesday, September 09, 2008 8:56 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] why specify spheroid?
> distance_sphere and distance_spheroid don't even look at the srid of
the geometry fed to them
Why is that?
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080909/15d45453/attachment.html>
