[postgis-users] PDF version of manual?
Kevin Neufeld
kneufeld at refractions.net
Wed Sep 10 09:10:46 PDT 2008
Yeah, it looks like things got a little jumbled with the new
documentation shuffle.
I've reinstated the link on the documentation webpage to an older pdf I
found (version 1.3.2). (http://postgis.refractions.net/docs/postgis.pdf
). In my spare time, I'll work to update the postgis autobuild process
to update this file on a regular basis.
Cheers,
Kevin
Paragon Corporation wrote:
> Tim,
> Strange the pdf version used to be
> http://postgis.refractions.net/docs/postgis.pdf but I guess things got
> reshuffled with the new documentation effort. Maybe Paul can put a link to
> the current 1.3.3 somewhere. Anyrate hopefully we'll have the pdf version
> back in line at some point.
> There is a lot of effort currently going on to try to improve the docs. The
> 1.4 is very in flux, but you can get a sense of how the new layout will be
> by looking at the section 7 work in progress for 1.4
> http://postgis.refractions.net/documentation/manual-svn/ch07.html
> The plan is to have a page for each function with examples and graphics.
> Then have accompnaying pdf version also automatically built.
> Kevin Neufeld setup the basic structure for the new doc layout and also has
> an automated build that updates the html online docs as changes are being
> made. Very cool.
> Hope that helps,
> Regina
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Tim
> Bowden
> Sent: Tuesday, September 09, 2008 9:24 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] PDF version of manual?
> It appears to be no longer there, but instead we have the manual for the
> next as yet unreleased point version of postgis: 1.3.4. It is good to see
> an open source project giving documentation suitable attention and keeping
> it up to date (unlike many open source projects). I'm surprised though that
> the documentation is released before the code. I suspect that's
> unprecedented.
> Regards,
> Tim Bowden
> On Tue, 2008-09-09 at 20:35 +0200, Hernán De Angelis wrote:
>> Hi,
>> Is there a PDF file of the manual for the most recent version of PostGIS?
>> In the past there used to be on link in the page to a PDF version, but
>> now I cannot find it.
>> Thanks in advance,
> Experience is that marvelous thing that enables you recognize a mistake when
> you make it again.
> postgis-users mailing list
