[postgis-users] Any Projected Straights Function?
Fonseca Hespanha de Oliveira, Joao da J.P.daFonsecaHespanhadeOliveira at tudelft.nl
Thu Sep 11 09:32:09 PDT 2008
Hi!
I am currently doing research on UML modeling of cadastre and land administration data. On a Object Diagram, there is a situation where a check should be done on the projected straights of a building outline (original building to be depicted in 3D), in order to see if it is contained within a land parcel (depicted on a 2D planar partition).
I check both the ISO 13249-3 (SQL/MM Part3: Spatial) and PostGIS documentation and could not find any explicit reference. So, can PostGIS do this kind of check?
João Paulo Hespanha
Technical University Delft
OTB Research Institute
PhD Student - GiST & GIGB Sections
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080911/b77fc1cd/attachment.html>
