[postgis-users] Function 60821c60 returned NULL
David R Robison
drrobison at openroadsconsulting.com
Thu Sep 11 10:57:35 PDT 2008
My version is 1.1.6. Can I upgrade just the PostGIS version without
upgrading PostgreSQL? I am running PostgreSQL 8.2. David
Mark Cave-Ayland wrote:
>> I have a PostGIS database that is frequently thowing this error. My
>> guess is that it is related to the GIS index and the number of NULL
>> geometries in the table. Because of how I am using Hibernate, I insert
>> the record with a NULL geometry and then update the record with the
>> geometry. Has anyone else identified this error and can anyone suggest a
>> fix?
>> Thanks, David
> Hi David,
> Which versions of PostGIS are you using? (SELECT postgis_full_version()).
> If it's earlier than 1.2.1, it sounds like you could be hitting the GiST
> index bug documented here:
> http://postgis.refractions.net/documentation/manual-svn/release_notes.html#id2692480.
> HTH,
> Mark.
David R Robison
Open Roads Consulting, Inc.
708 S. Battlefield Blvd., Chesapeake, VA 23322
phone: (757) 546-3401
e-mail: drrobison at openroadsconsulting.com
web: http://openroadsconsulting.com
blog: http://therobe.blogspot.com
book: http://www.xulonpress.com/book_detail.php?id=2579
This e-mail communication (including any attachments) may contain confidential and/or privileged material intended solely for the individual or entity to which it is addressed. If you are not the intended recipient, you should immediately stop reading this message and delete it from all computers that it resides on. Any unauthorized reading, distribution, copying or other use of this communication (or its attachments) is strictly prohibited. If you have received this communication in error, please notify us immediately.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080911/816c039c/attachment.html>
