[postgis-users] intersects() yields "TopologyException: side location conflict"
Reid Priedhorsky reid at umn.edu
Tue Sep 16 10:55:56 PDT 2008
Dear all,
PostGIS is failing on one of my tables with the following in the logs:
2008-09-16 01:27:31 CDT NOTICE:  TopologyException: side location conflict 464854 4.96637e+06
2008-09-16 01:27:31 CDT ERROR:  GEOS intersects() threw an error!
2008-09-16 01:27:31 CDT STATEMENT:
                    SELECT
                           id,
                           version,
                           name,
                           type_code,
                           draw_class_code,
                           z,
                           valid_starting_rid,
                           valid_before_rid,
                           AsSVG(Scale(geometry, 1, -1, 1), 0, 2) as geometry
                    FROM (basemap_polygon bp JOIN basemap_polygon_type
                          ON (type_code = basemap_polygon_type.code))
                    WHERE
                      (Intersects(bp.geometry, SetSRID('BOX(459128.000000 4962591.500000, 463188.000000 4966303.500000)'::box2d, 26915)))
                      AND
                      (    valid_before_rid = rid_inf()
                         AND NOT deleted)
The table (6k rows) looks like this:
                            Table "public.basemap_polygon"
       Column       |   Type   |                      Modifiers
 id                 | integer  | not null default nextval('feature_id_seq'::regclass)
 version            | integer  | not null
 deleted            | boolean  | not null
 name               | text     |
 type_code          | integer  | not null
 valid_starting_rid | integer  | not null
 valid_before_rid   | integer  | not null
 geometry           | geometry | not null
 z                  | integer  | not null
Indexes:
    "basemap_polygon_pkey" PRIMARY KEY, btree (id, version)
    "temp2" UNIQUE, btree (id)
    "basemap_polygon_gist" gist (geometry)
    "basemap_polygon_valid_before_rid" btree (valid_before_rid)
    "basemap_polygon_valid_starting_rid" btree (valid_starting_rid)
Check constraints:
    "enforce_dims_geometry" CHECK (ndims(geometry) = 2)
    "enforce_geotype_geometry" CHECK (geometrytype(geometry) = 'POLYGON'::text OR geometry IS NULL)
    "enforce_srid_geometry" CHECK (srid(geometry) = 26915)
    "enforce_version" CHECK (version >= 1)
Foreign-key constraints:
    "basemap_polygon_type_code_fkey" FOREIGN KEY (type_code) REFERENCES basemap_polygon_type(code) DEFERRABLE
    "basemap_polygon_valid_before_rid_fkey" FOREIGN KEY (valid_before_rid) REFERENCES revision(id) DEFERRABLE
    "basemap_polygon_valid_starting_rid_fkey" FOREIGN KEY (valid_starting_rid) REFERENCES revision(id) DEFERRABLE
PostGIS version info:
                               postgis_full_version
 POSTGIS="1.3.3" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.6.0, 21 Dec 2007" USE_STATS
Please advise.
Is this a GEOS bug? Has it been fixed?
How can I identify which row(s) in my table is/are causing the exception? They may turn out to be unimportant, in which case I can delete them as a workaround.
Let me know what additional info I should provide.
Thanks,
Reid
