[postgis-users] visually linking the polygons of multipolygon layer
pcreso at pcreso.com pcreso at pcreso.com
Tue Sep 16 12:23:22 PDT 2008
Looks simple enough, but you may need to find some way of ordering the centroids to have a sensible line progressing through the individual polygons.
I guess you could stick an order by X() or Y() of the centroid's coords so the lines always run EW or NS??
Cheers,
  Brent Wood
--- On Wed, 9/17/08, Obe, Regina <robe.dnd at cityofboston.gov> wrote:
> From: Obe, Regina <robe.dnd at cityofboston.gov>
> Subject: RE: [postgis-users] visually linking the polygons of multipolygon layer
> To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
> Date: Wednesday, September 17, 2008, 2:15 AM
> First thing that comes to mind to me is string the centroids
> together.
> Something like
> SELECT gid, ST_MakeLine(ST_Centroid(the_geom)) As arc
> FROM (SELECT gid, (ST_Dump(the_geom)).geom As the_geom
>                 FROM multipolytable
> ) As foo
> GROUP BY gid
> Hope that helps,
> Regina
> ________________________________
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of erik
> Sent: Tuesday, September 16, 2008 9:06 AM
> To: PostGIS Users Discussion
> Subject: [postgis-users] visually linking the polygons of
> multipolygon
> layer
> Hi,
> I'm not sure I know how to formulate this
> I have a set of Multipolygons. I'd like to link somehow
> the polygons of
> each multipolygon  with a "string", an arc, that
> expresses their
> belonging to the same polygon.
> Is this possible, is there some predefined function that
> could
> accomplish this?
> Many thanks,
> Erik
> The substance of this message, including any attachments,
> may be
> confidential, legally privileged and/or exempt from
> disclosure
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error,
> please
> contact the sender and delete the material from any
> computer.
> postgis-users mailing list
