[postgis-users] make the buffer in 3d
Kevin Neufeld
kneufeld at refractions.net
Wed Sep 17 14:51:39 PDT 2008
Do you mean you want to select all point features in a specific cylinder?
Well, you could do it in a 3D bounding box (using cube), but I don't
know of an easy way to filter which points lie in your 3d box, but
outside the cylinder. I suspect you'll have to write a custom plpgsql
function and do some math in there ... returning true or false
appropriately.
On a side note, this example shows how to build a 3D index on a geometry.
-- Create 10,000 3D points randomly for a sample dataset
CREATE TEMP TABLE tmp AS
SELECT
ST_MakePoint(random()*1000, random()*1000, random()*1000) AS the_geom
FROM generate_series(1, 10000);
-- Create a 3D index on the geometry
CREATE INDEX tmp_geom_cube_idx ON tmp USING GIST (
cube(
cube(
cube(ST_XMin(the_geom), ST_XMax(the_geom)),
ST_YMin(the_geom),
ST_YMax(the_geom)
ST_ZMin(the_geom),
ST_ZMax(the_geom)
ANALYZE tmp;
-- SELECT the points that lie within the z-value range [500,501]
SELECT ST_AsEWKT(the_geom)
FROM tmp
WHERE '(0,0,500),(1000,1000,501)'::cube @>
cube(
cube(
ST_YMin(the_geom),
ST_YMax(the_geom)
ST_ZMin(the_geom),
ST_ZMax(the_geom)
st_asewkt
POINT(226.273822132498 958.905964624137 500.327607151121)
POINT(578.404269646853 912.93861810118 500.205896329135)
POINT(829.249489121139 923.576071392745 500.778052955866)
POINT(677.46328888461 946.14454684779 500.152825843543)
POINT(807.106878608465 67.1494407579303 500.44699665159)
POINT(494.829344097525 620.502772275358 500.783439725637)
(6 rows)
Cheers,
Kevin
eehab hamzeh wrote:
> Hello,
> I have a point feature, i need to buffer this point by specific
> distance. then extrude the resulted circle by the same buffer distance.
> Is there is a possibility to select all the feature that are in the 3d
> space of this feature.
> Thanks
