[postgis-users] problems with transformation
Stefan Zweig
stefanzweig1881 at web.de
Thu Sep 18 04:45:22 PDT 2008
hi list,
im a using two different installations of postgis. the first (1.) is for testing the second (2.) for working.
(1.)
select postgis_full_version()
"POSTGIS="1.3.3" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.6.0, 21 Dec 2007" USE_STATS"
(2.)
"POSTGIS="1.2.1" GEOS="2.2.3-CAPI-1.1.1" PROJ="Rel. 4.5.0, 22 Oct 2006" USE_STATS"
i am running the same query on both installations, getting different results:
(1.)
select st_y (transform(setsrid(makepoint(-626172.139189,7514065.62361),9805), 4326));
55.7765729937296
(2.)
55.9549116318344
the content for the srids 4326 and 9805 is equal on both installations:
(1.) + (2.)
select * from spatial_ref_sys where srid = 4326 or srid = 9805
srid;auth_name;auth_srid;srtext;proj4text
4326;EPSG;4326;GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]];+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs
9805;EPSG;9805; ;+proj=merc +lat_ts=0 +lon_0=0 +x_0=0 +y_0=0 +a=6378137 +b=6378137 +units=m +no_defs
actually i would suppose to get same results on both installations using transform() if the srid entries on both installations are equal. is there another point than the spatial_ref_sys table where the coordinate systems information can be set?
to me it seems like installation (1.) calculates the transformation using a spheroid and (2.) using the wgs84 ellipsoid.
any advices?
thanks in advance + regards. stefan
________________________________________________________________________
Schon gehört? Bei WEB.DE gibt' s viele kostenlose Spiele:
http://games.entertainment.web.de/de/entertainment/games/free/index.html
