[postgis-users] make the buffer in 3d
Obe, Regina
robe.dnd at cityofboston.gov
Thu Sep 18 05:42:12 PDT 2008
Eehab,
If you are just dealing with point geometries and you care about just 3d
distance rather than representation, then , use ST_Length3D. There is
no distance 3d, but there is a length 3d.
Although I think I answered this question before so maybe there was
something wrong with my answer. It would be helpful to know what was
wrong with the answer. I admit I didn't really try it.
Also shouldn't your visual result be a sphere rather than a cylinder?
Where is your cylinder coming from?
Anyrate here is my answer again
In this case, I'm going to assume p is ST_MakePoint(1,2,3) and your 3d
limiting distance is 10
SELECT gid, the_geom
FROM sometable, (SELECT ST_MakePoint(1,2,3) As the_geom) As p
WHERE ST_DWithin(sometable.the_geom, p.the_geom, 10)
AND ST_Length3D(ST_MakeLine(sometable.the_geom, p.the_geom)) < 10
(The ST_DWithin even though its a 2d check, will be useful because it
will use indexes and any 3D check would have to pass the 2D check)
Thanks,
Regina
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
eehab hamzeh
Sent: Thursday, September 18, 2008 5:41 AM
To: Kevin Neufeld; PostGIS Users Discussion
Subject: RE: [postgis-users] make the buffer in 3d
Kevin,
Thank you, i need to:
1) create buffer in 3d. I mean the resulted buffer should have z value.
the z value will be equal to the radius value.
2) select all features that are intersect this cylinder, or inside this
cylinder.
Thanks
Get news, entertainment and everything you care about at Live.com. Check
it out! <http://www.live.com/getstarted.aspx>
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080918/90bb1d58/attachment.html>
