[postgis-users] PostGIS topology
Nandorov nandorov at gmail.com
Fri Sep 19 09:20:39 PDT 2008
Hello,
Thanks for your replies.  i read the info in
http://postgis.com/support/wiki/index.php?PostgisTopology
Mark, have you worked with GEOS before? I'm going to use windows enviroment
and i guess i have to build my own installer.(I found GEOS for Linux and
API's for a windows build) it's GEOS a good choice? and how does it works
exactly? thanks
best regards
Mark Leslie-3 wrote:
> Daniel Kastl wrote:
>> Nandorov schrieb:
>>> Hi,
>>> How can i make a topology in PostGIS?
>>> Best regards
>> Hi,
>> Not sure whether this is exactly what you're looking for, but pgRouting
>> has a function to create a network topology for routing.
>> The function is called name is "assign_vertex_id".
>> (http://pgrouting.postlbs.org/wiki/Workshop-PrepareDikstra)
>> Daniel
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> This may also be of some help.
> http://postgis.refractions.net/support/wiki/index.php?PostgisTopology
> Mark Leslie
> Geospatial Software Architect
> LISAsoft
> Ph: +61 2 8570 5000 Fax: +61 2 8570 5099 Mob: +61
> Suite 112, Jones Bay Wharf 19-21 Pirrama Rd Pyrmont NSW 2009
> LISAsoft is part of the A2end Group of Companies
> http://www.ardec.com.au
> http://www.lisasoft.com
> http://www.terrapages.com
View this message in context: http://www.nabble.com/PostGIS-topology-tp19560868p19575331.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
