[postgis-users] ArcGIS Mobile slightly off-topic question
David Fawcett david.fawcett at gmail.com
Fri Sep 19 14:13:37 PDT 2008
Malkovich, Malkovich, Malkovich
If you are just updating attributes and they don't participate in any
of the fancy geodatabase stuff (domains, etc.), using Access SQL
should work.  If you are editing geometries or they are using the
geodatabase stuff, you will probably need/want to use the ESRI Python
module.
David.
On Fri, Sep 19, 2008 at 3:46 PM, Obe, Regina <robe.dnd at cityofboston.gov> wrote:
> David,
> Yes.  Right now I'm using OGR to read data and that works fine, so its
> writing back an updated set that's the problem.
> Actually I'm not sure if the mobile replication thing is going to cause
> me problems in addition to the regular issues with geodatabase.
> The main issue is that some fields are updated in the field as well as
> in the office.  For the most part they aren't the same fields so I don't
> have to worry about collision, but the field needs to see some data that
> is updated in the office.
> (just realized I'm using field to mean 2 different things.  sorry about
> that - I feel like I'm in that maflar south park episode where there is
> only one word in the alien vocabulary :)).
> Thanks,
> Regina
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> David Fawcett
> Sent: Friday, September 19, 2008 4:37 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] ArcGIS Mobile slightly off-topic question
> For reading the personal geodatabase, don't forget that on Windows,
> OGR can read the data without using ODBC.
> http://www.gdal.org/ogr/drv_pgeo.html
> As long as you have an ArcInfo license, the ESRI python to read and
> write to the geodatabase is really pretty straight forward.  (it
> doesn't run as fast as the OS stuff, but the documentation is better
> and the user community is much larger)
> What exactly was your data flow again?
> attributes and geometries from pgeodb to postgis and then attributes
> and geoms back to the geodatabase?
> David.
> On Fri, Sep 19, 2008 at 11:37 AM, Martin Davis <mbdavis at refractions.net>
> wrote:
>> That's correct - in a Personal GDB, the BLOB field holding the
> geometry has
>> the same format as individual geometries in the Shapefile format.
>> Reading a PGDB is thus relatively easy.  Writing them is probably a
> whole
>> lot harder, because there's a bunch of metadata/spatial index stuff
> that
>> would need to be written as well IIRC.
> postgis-users mailing list
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and delete the material from any computer.
