[postgis-users] area resulting from ST_Within
surya
storma-ipb at indo.net.id
Sun Sep 21 09:41:40 PDT 2008
Dear Fred,
Thank you very much. It works correctly !!. I try to further convert the area of each district in a watershed as percentage to the watershed area in question. Please give me more help.
best regards,
surya
----- Original Message -----
To: PostGIS Users Discussion
Sent: Sunday, September 21, 2008 4:35 PM
Subject: Re: [postgis-users] area resulting from ST_Within
Hi Surya,
you can try something like that:
SELECT ws.name,dt.name, sum(ST_area(ST_intersection(ws.the_geom,dt.the_geom)))
FROM watersheds as ws, districts as dt
WHERE ST_intersects(ws.the_geom,dt.the_geom)
GROUP BY ws.name,dt.name
ORDER BY dt.name
Fred.
On Sun, Sep 21, 2008 at 3:37 AM, surya <storma-ipb at indo.net.id> wrote:
Dear List,
I have two tables, one table contains 5 polygons depicting 5 watersheds or river basin boundaries. Another table contain district bondaries. Using ST-contain function below, I have obtained districts belong to a certain watershed . My qestion is how to calculate area of each district contained in a certain watershed using sum(area)(), taking into consideration that one district might be splitted in two or more different watershed
SELECT watersheds.name, districts.name
FROM watersheds, districts
WHERE ST_contains (watersheds.the_geom, districts.the_geom)
GROUP BY watersheds.name, districts.name ;
best regards,
surya
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080921/8056a3c2/attachment.html>
