[postgis-users] PostGIS topology
mchapman at fortifieddatacom.com mchapman at fortifieddatacom.com
Sun Sep 21 16:53:49 PDT 2008
I use geos directly on windows xp using visual studio 2005.  How do you plan to use it?
Martin
------Original Message------
Sender: postgis-users-bounces at postgis.refractions.net
To: PostGIS Users Discussion
ReplyTo: PostGIS Users Discussion
Sent: Sep 21, 2008 5:33 PM
Subject: Re: [postgis-users] PostGIS topology
Nandorov wrote:
> Hello,
> Thanks for your replies.  i read the info in
> http://postgis.com/support/wiki/index.php?PostgisTopology
> Mark, have you worked with GEOS before? I'm going to use windows enviroment
> and i guess i have to build my own installer.(I found GEOS for Linux and
> API's for a windows build) it's GEOS a good choice? and how does it works
> exactly? thanks
> best regards
I haven't worked directly in GEOS much at all.  Before you go the route
of building on Windows, what exactly are you trying to do?
Mark Leslie
Geospatial Software Architect
LISAsoft
Ph: +61 2 8570 5000 Fax: +61 2 8570 5099 Mob: +61
Suite 112, Jones Bay Wharf 19-21 Pirrama Rd Pyrmont NSW 2009
LISAsoft is part of the A2end Group of Companies
http://www.ardec.com.au
http://www.lisasoft.com
http://www.terrapages.com
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
Sent via BlackBerry by AT&T
