[postgis-users] area resulting from ST_Within
surya
storma-ipb at indo.net.id
Mon Sep 22 05:44:57 PDT 2008
Dear Regina,
Watershed table has only one name per record. The first SQL that you
proposed works very well. However, the second SQL is also very interesting
to understand for future analysis. Is there any guideline how to assemble
such complicated but useful SQL.
best regards,
surya
----- Original Message -----
To: "'PostGIS Users Discussion'" <postgis-users at postgis.refractions.net>
Sent: Monday, September 22, 2008 11:07 AM
Subject: RE: [postgis-users] area resulting from ST_Within
> Surya,
> Sorry about that. I realize now I misspoke.
> If your watersheds are 1 per record, then the answer should be as simple
> as
> SELECT ws.name,dt.name ,
> sum(ST_area(ST_intersection(ws.the_geom,dt.the_geom)))/st_area(ws.the_geom)
> As pct
> FROM watersheds as ws INNER JOIN districts as dt
> ON ST_intersects(ws.the_geom,dt.the_geom)
> GROUP BY ws.name , dt.name , ST_area(ws.the_geom)
> ORDER BY dt.name
> If they are multiple water shed records with same name and you need to add
> them up, then answer is a bit more complicated and probably slower but
> more
> generic solution would be
> sum(ST_area(ST_intersection(ws.the_geom,dt.the_geom)))/wa.thearea As pct
> FROM watersheds as ws INNER JOIN (SELECT ST_Sum(st_area(the_geom)) As
> thearea, name FROM watersheds GROUP BY name) As wa ON wa.name = ws.name
> INNER JOIN districts as dt ON
> GROUP BY ws.name , wa.name, dt.name , wa.thearea
> ORDER BY dt.name
> Hope that helps,
> Regina
> ________________________________
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of surya
> Sent: Sunday, September 21, 2008 11:35 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] area resulting from ST_Within
> Dear PC,
> After summing up percentage of all districts in one watershed, it does
> not
> add up to 100%. Moreover, after multiplication with 100, the total
> percentage of all districts in one watershed is far below 100%.
> In the first watershed, I have 9 different districts. The first district
> calculated with the term:
> sum(ST_area(ST_intersection(ws.the_geom,dt.the_geom))) gives 25 sq. km,
> meanwhile the watershed area itself is 646 sq. km. Therefore, the
> percentage
> of this district should be (25/646)* 100 = 3.9 %.
> Using the proposed term tocalculate percentage:
> (sum(ST_area(ST_intersection(ws.the_geom,dt.the_geom)))/sum(st_area(ws.the_g
> eom)))*100 gives only 0.18 % instead. I do not know what is wrong.
> best regards,
> surya
> From: Paragon Corporation <mailto:lr at pcorp.us>
> To: 'PostGIS Users Discussion'
> <mailto:postgis-users at postgis.refractions.net>
> Sent: Monday, September 22, 2008 4:44 AM
> Try
> SELECT ws.name <http://ws.name/> ,dt.name <http://dt.name/> ,
> sum(ST_area(ST_intersection(ws.the_geom,dt.the_geom)))/sum(st_area(ws.the_ge
> om)) As pct
> FROM watersheds as ws, districts as dt
> WHERE ST_intersects(ws.the_geom,dt.the_geom)
> GROUP BY ws.name <http://ws.name/> ,dt.name <http://dt.name/>
> ORDER BY dt.name <http://dt.name/>
> Sent: Sunday, September 21, 2008 12:42 PM
> Dear Fred,
> Thank you very much. It works correctly !!. I try to further convert
> the area of each district in a watershed as percentage to the watershed
> area in question. Please give me more help.
> best regards,
> surya
> From: Fred Lehodey <mailto:lehodey at gmail.com>
> Sent: Sunday, September 21, 2008 4:35 PM
> Hi Surya,
> you can try something like that:
> SELECT ws.name,dt.name,
> GROUP BY ws.name,dt.name
> ORDER BY dt.name
> Fred.
> On Sun, Sep 21, 2008 at 3:37 AM, surya
> <storma-ipb at indo.net.id> wrote:
> Dear List,
> I have two tables, one table contains 5 polygons
> depicting 5 watersheds or river basin boundaries. Another table contain
> district bondaries. Using ST-contain function below, I have obtained
> districts belong to a certain watershed . My qestion is how to calculate
> area of each district contained in a certain watershed using sum(area)(),
> taking into consideration that one district might be splitted in two or
> more
> different watershed
> SELECT watersheds.name <http://watersheds.name/> ,
> districts.name <http://districts.name/>
> FROM watersheds, districts
> WHERE ST_contains (watersheds.the_geom,
> districts.the_geom)
> GROUP BY watersheds.name <http://watersheds.name/> ,
> districts.name <http://districts.name/> ;
> best regards,
> surya
> postgis-users mailing list
