[postgis-users] PostGIS topology
Nandorov
nandorov at gmail.com
Mon Sep 22 13:39:55 PDT 2008
Martin, how can i make GEOS run on windows?
thanks
mchapman wrote:
> I use geos directly on windows xp using visual studio 2005. How do you
> plan to use it?
> Martin
> ------Original Message------
> From: Mark Leslie
> Sender: postgis-users-bounces at postgis.refractions.net
> To: PostGIS Users Discussion
> ReplyTo: PostGIS Users Discussion
> Sent: Sep 21, 2008 5:33 PM
> Subject: Re: [postgis-users] PostGIS topology
> Nandorov wrote:
>> Hello,
>> Thanks for your replies. i read the info in
>> http://postgis.com/support/wiki/index.php?PostgisTopology
>> Mark, have you worked with GEOS before? I'm going to use windows
>> enviroment
>> and i guess i have to build my own installer.(I found GEOS for Linux and
>> API's for a windows build) it's GEOS a good choice? and how does it works
>> exactly? thanks
>> best regards
> I haven't worked directly in GEOS much at all. Before you go the route
> of building on Windows, what exactly are you trying to do?
> Mark Leslie
> Geospatial Software Architect
> LISAsoft
> Ph: +61 2 8570 5000 Fax: +61 2 8570 5099 Mob: +61
> Suite 112, Jones Bay Wharf 19-21 Pirrama Rd Pyrmont NSW 2009
> LISAsoft is part of the A2end Group of Companies
> http://www.ardec.com.au
> http://www.lisasoft.com
> http://www.terrapages.com
> postgis-users mailing list
> Sent via BlackBerry by AT&T
View this message in context: http://www.nabble.com/PostGIS-topology-tp19560868p19616041.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
