[postgis-users] ST_Buffer() never returns
    Martin Davis
    mbdavis at refractions.net
    Wed Sep 24 09:41:27 PDT 2008
Cool, that's very useful feedback.   This would be worth capturing in
the PG wiki...
Andi Vajda wrote:
> On Sep 24, 2008, at 8:45, Martin Davis <mbdavis at refractions.net> wrote:
>> Wow!  It's great that this works for you - and I'm happy that you are
>> able to use the word "fast" as well!
>> I would have expected that say 3 levels of buffering would have been
>> sufficient.  Did you try that first, and found you had to move to
>> more levels?
> I first went with two levels: 0.0001 and 0.1. While it worked, it took
> several minutes for some shapes. Inserting the 0.001 and 0.01 levels
> made it all much much faster. I could then update all 2654 shapes in
> question in about a
> minute or two.
> Andi..
>> Martin
>> Andi Vajda wrote:
>>> On Fri, 12 Sep 2008, Martin Davis wrote:
>>>> This is an example of a known issue with GEOS/JTS buffering.  The
>>>> problem occurs when using a relatively large buffer distance on
>>>> geometries which have a large number of vertices which are
>>>> relatively dense (i.e. the distance between adjacent vertices is
>>>> much smaller than the requested buffer distance).
>>>> A couple of ways to avoid this problem are:
>>>> - simplify the input geometry using a tolerance which gets rid of
>>>> most of the very dense vertices (use a tolerance of say from 1% to
>>>> 10% of the buffer distance)
>>>> - buffer the geometry mulitple times, starting with a very small
>>>> buffer distance and gradually increasing it
>>> Thanks, with your tip, I defined the following function which made
>>> it work (and fast) for all the shapes in my db:
>>> CREATE OR REPLACE FUNCTION gix_make_shell(geometry)
>>> RETURNS geometry AS $$
>>>    SELECT
>>> ST_Simplify(ST_Buffer(ST_Simplify(ST_Buffer(ST_Simplify(ST_Buffer(ST_Simplify(ST_Buffer($1,
>>> 0.0001), 0.0001), 0.001), 0.001), 0.01), 0.01), 0.1), 0.1)
>>> $$ LANGUAGE SQL STABLE;
>>> Andi..
>> Martin Davis
>> Senior Technical Architect
>> Refractions Research, Inc.
>> (250) 383-3022
Martin Davis
(250) 383-3022
