[postgis-users] Re: PostGIS PDF using dblatex/pdflatex
Jean David TECHER david.techer at davidgis.fr
Thu Sep 25 03:49:23 PDT 2008
Hi Kevin,
Thanks for your comments.
The instructions are available on my Web Site at
http://www.davidgis.fr/blog/index.php?2008/09/25/387-building-pdf-for-postgis-using-dblatex
I've tried to write in English...Hope this helps!
Best regards.
--david;
Quoting Kevin Neufeld <kneufeld at refractions.net>:
> Hi David,
> Is there any chance you remember the syntax and parameters used to
> generate your pdf?  It would be sweet if we could incorporate such a
> doc in our automatic build system so it stays current.
> Cheers,
> Kevin
> Kevin Neufeld wrote:
>> Very nicely done David.
>> PaulR - are you really set on producing a PDF via Apache's FOP?
>> This looks far better than anything I've been able to reproduce
>> with FOP or Docbook's db2pdf.
>> David, what exactly is your command line for generating the doc
>> (maybe I can put it in the autobuild process that gets updated on
>> every SVN commit)?  Assuming of course that folks are ok with
>> adding a new dependency with the build process ...
>> Cheers,
>> Kevin
>> Jean David TECHER wrote:
>>> Dear all,
>>> I've tried to compil the postgis.pdf using the svn tarball.
>>> The output is available at
>>> http://www.davidgis.fr/postgis-out.pdf
>>> AFAIK, the output seems to be beautifull since you can see the images.
>>> Hope these help people for a printing solution for postgis doc  ;)
>>> --david;
>>> Jean David TECHER
>>> www.davidgis.fr
>>> 06 60 46 85 05
>>> 04 99 77 16 87
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
Jean David TECHER
www.davidgis.fr
06 60 46 85 05
04 99 77 16 87
