[postgis-users] Determining file's bit encoding
paul919
nrpaul at gmail.com
Fri Sep 26 12:05:42 PDT 2008
Hello,
I am trying to import data into a PostGIS database that is using the UTF8
bit encoding. However several of the .shp files that i am importing have a
different bit encoding and it will not let me import the data into PostGIS
unless the bit encodings are the same. First question, is there anyway
around this?
If not, I can use the linux iconv utility to convert the files to the
correct UTF8 bit encoding, however i need to know what the current encoding
is on the files. Second question, how do i determine the bit encoding on a
file?
Thank you in advance for you help.
View this message in context: http://www.nabble.com/Determining-file%27s-bit-encoding-tp19694595p19694595.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
