[postgis-users] GeometryCollection(Empty) is SRID dependent (or supporting nulls in st_union)
Charlie Savage
cfis at savagexi.com
Fri Sep 26 21:23:54 PDT 2008
In postgis sending null to functions such as st_union causes the result
to be null. To get around that, postgis defines the collection of an
empty geometry as GEOMETRYCOLLECTION(EMPTY). As a result, in our
application we check for null geometry bounds, and if they are null,
substitute an empty collection.
The problem with this is doesn't work if you have geometries in
different SRIDs. For example:
select asewkt(st_union('srid=4326;point(1 1)'::geometry,
'GEOMETRYCOLLECTION(EMPTY)'::geometry))
ERROR: Operation on mixed SRID geometries
Since we're substituting out for null geometries, we can't know what the
correct SRID is for the empty geometry collection. Thus when these
empty collections are unioned with other geometries they will blow up if
they don't share the same srid.
So a proposal - checking the SRID values for Empty Geometry collection
should be dropped. Since the geometry is empty, it has no effect on the
final calculations anyway, I don't think this change would break any code.
The other way I around this is to fix st_union and other functions to
ignore nulls. This would be more inline with what postgresql does with
other aggregates:
select sum(numbers.value)
from
(select 1 as value
union
select null as value) as numbers
The result is 1, not null.
The 2nd options seems nicer to me (the empty geometry collection idea
has always seemed a big kludge to me), but either would work for us.
Thoughts?
Charlie
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080926/2cf44798/attachment.bin>
