[postgis-users] ST_SPHEROID_LENGTH SLOW
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Sun Sep 28 00:02:27 PDT 2008
Hi David,
> Hi,
> I am a debian user, several months ago debian testing introduced
> postgresql-8.3, and later postgis 1.3 for postgresql-8.3. The problem I
> am facing is that length_spheroid is much slower in postgres-8.3 from
> under 1s to about 60s (See Bellow). I have google-it without any luck.
> Does anyone have any idea on why this happens?
Firstly it is not the length_spheroid function that is being slow here -
the time is disappearing into the index scan on your primary key.
> Both databases are equal, tested in same machine, with different
> installations to avoid software versions conflicts.
Something doesn't quite ring true here. Looking at your results below I
see this:
> FIRST:
> postgresql-8.2 (version 8.2.7-2+b1) with postgis (version 1.3.2-1)
(cut)
> -> Index Scan using test_pkey on test (cost=0.00..2268.52
> rows=13010 width=26054) (actual time=1.850..588.298 rows=100 loops=1)
(cut)
> SECOND:
> postgresql-8.3 (version 8.3.3-1) with postgis (version 1.3.3-3)
> -> Index Scan using test_pkey on test (cost=0.00..1137.11
> rows=13010 width=104429) (actual time=182.732..59741.572 rows=100 loops=1)
The width parameter gives what PostgreSQL thinks is the average size of
a row for this scan, and the two are clearly different - are you sure
you have the same dataset on both systems?
Also you haven't mentioned anything about comparing settings in
postgresql.conf - are they the same, and are you definitely using
autovacuum on both systems? If not, a "VACUUM FULL test; REINDEX TABLE
test" may help if you are suffering from table/index bloat.
HTH,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
