[postgis-users] Determining file's bit encoding
Nick Paul
nrpaul at gmail.com
Mon Sep 29 08:01:38 PDT 2008
Hi Paul,
Thanks for answering my question. Do you know of anyway to tell which bit
encoding is used on a file. My data is coming from the middle east and I
don't know if the data is bad, or if I'm specifying the wrong encoding. For
example, using either LATIN1 and Cp1256 will execute without error, but the
data isn't responding the way I expected so I'm unsure if there is a problem
with the encoding or just the data.
Thank you for your help,
Nick
On Fri, Sep 26, 2008 at 3:18 PM, Paul Ramsey <pramsey at cleverelephant.ca>wrote:
> You don't need iconv, you can use the -W flag in shp2pgsql:
> shp2pgsql -W LATIN1 -s 4366 -D foo.shp foo
> If you're in a western country, your encoding is likely either LATIN1
> or WIN1252 (they are almost identical, the WIN one has some Windows
> special characters in it).
> Here's the list of possibilities:
> http://www.postgresql.org/docs/8.1/static/multibyte.html
> P.
> On Fri, Sep 26, 2008 at 12:05 PM, paul919 <nrpaul at gmail.com> wrote:
> > Hello,
> > I am trying to import data into a PostGIS database that is using the UTF8
> > bit encoding. However several of the .shp files that i am importing have
> a
> > different bit encoding and it will not let me import the data into
> PostGIS
> > unless the bit encodings are the same. First question, is there anyway
> > around this?
> > If not, I can use the linux iconv utility to convert the files to the
> > correct UTF8 bit encoding, however i need to know what the current
> encoding
> > is on the files. Second question, how do i determine the bit encoding on
> a
> > file?
> > Thank you in advance for you help.
> > View this message in context:
> http://www.nabble.com/Determining-file%27s-bit-encoding-tp19694595p19694595.html
> > Sent from the PostGIS - User mailing list archive at Nabble.com.
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080929/02b65701/attachment.html>
