[postgis-users] Re: Restoring db with indexes using PostGIS functions
Mike Leahy
mgleahy at alumni.uwaterloo.ca
Tue Sep 30 16:37:56 PDT 2008
Hello Regina,
There's no problems with table constraints or anything like that...the
only issue is with the indexes that use st_geometrytype. I can give the
compressed format a try...what version of PostgreSQL are you using?
I've got 8.3 on the machines I'm using, and I think the dump format has
changed slightly from one version to the next (though I'm not 100% sure
about that).
I don't normally set the search path either. As you recommend, I
explicitly reference the schema.table names in all of the SQL that I've
been writing myself. It's only when restoring the database that I've
encountered this.
Mike
Paragon Corporation wrote:
> Mike,
> I'm a bit puzzled about your problem. Are you saying that you use multiple
> schemas for tables and have your postgis functions in public and when you
> restore your indexes
> they are not being created because of the search path thing. I use multiple
> table schemas too and as far as I can remember all my spatial constraints
> and indexes come back and I don't see any prefixing of public in the
> functions.
> Although sounds like you are dumping to sql format and I always dump to
> compressed format. Perhaps they behave differently.
> Is it just your indexes that are missing or the constraints as well? Your
> indexes seem a little out of the ordinary, but I would expect you would have
> the same issue
> With postgis generated constraints. Do your table indexes actually show
> without the schema qualification on them when you look at them.
> Mine always show as
> CREATE INDEX sometable_idx
> ON someschema.sometable
> USING btree
> (ST_GeometryType(the_geom));
> But then again I always explicitly put in the schema prefix when creating
> indexes. How would you be able to create the indexes otherwise unless you
> are setting the search path before you create your indexes
> Set search_path = schemaname
> CREATE INDEX ... ON sometable
> Is that how you create your indexes or do you explicitly reference the table
> schema name in the CREATE?
> Hope that helps,
> Regina
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Mike
> Leahy
> Sent: Tuesday, September 30, 2008 4:00 PM
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] Re: Restoring db with indexes using PostGIS
> functions
> Mark Cave-Ayland wrote:
>> Mike Leahy wrote:
>>> Hello list,
>>> I ran into a problem today when restoring a database of mine - I'm not
>>> sure if this is anything new, or if I'm doing something I shouldn't be
>>> doing. I have in my db a variety of tables that are stored in separate
>>> schemas. Some of these tables have geometry columns that I am using to
>>> store variable geometry types, but since most of the queries on these
>>> tables generally focus on one geometry type at a time, I added indexes
>>> to them as follows:
>>> CREATE INDEX mytable_geomtype_idx ON schemaname.mytable USING btree
>>> (st_geometrytype(geom));
>>> However, when I dump the database, the resulting sql sets search paths
>>> rather than explicitly naming schema.table in each statement.
>>> Effectively, this is what happens when the dumped sql is loaded into a
>>> new database:
>>> mydb=# SET search_path = schemaname, pg_catalog;
>>> SET
>>> mydb=# CREATE INDEX mytable_geomtype_idx ON mytable USING btree
>>> (public.st_geometrytype(geom));
>>> ERROR: function geometrytype(public.geometry) does not exist
>>> LINE 1: SELECT geometrytype( $1 )
>>> HINT: No function matches the given name and argument types. You might
>>> need to add explicit type casts.
>>> QUERY: SELECT geometrytype( $1 )
>>> CONTEXT: PL/pgSQL function "st_geometrytype" line 6 during statement
>>> block local variable initialization
>>> mydb=#
>>> It seems that setting the search path has undesirable effects with the
>>> st_geometrytype function (I don't know if the same happens with other
>>> functions). I suspect 'geometrytype( $1 )' would have to be substituted
>>> with 'public.geometrytype( $1 )' for this to work.
>>> Is this just something I should be aware of? It's not a show-stopper
>>> for me at the moment, but it means that I'd have to manually recreate
>>> any indexes like the one above if performance became an issue after
>>> restoring the database (not in my current situation, but maybe down the
>>> road).
>>> Regards,
>>> Mike
>> Hi Mike,
>> If you are using newer PostgreSQL releases, there was an issue a while
>> back where the use of search_path within stored procedures was
>> restricted to stop people from overriding in-built stored procedures.
>> Otherwise it could simply be that the dump ordering is wrong, and
>> altering the restore order so that geometrytype() is restored *before*
>> ST_geometrytype should resolve the issue.
>> HTH,
>> Mark.
> Hello Mark,
> I don't think it is a problem with the order of restoration of the
> geometrytype() vs. st_geometrytype() functions, because those are loaded
> and working fine before anything else happens in the restore script.
> The problem is when indexes are being restored for the tables inside my
> schemas - the dump script will set the search path for one schema,
> create the indexes, then repeat for any other schemas. It does this
> throughout from what I can tell.
> This problem, from what I can tell, is not limited to the restore
> scripts. The problem occurs just by setting the search path to
> something other than 'public', then calling public.st_geometrytype(),
> which in turn calls geometrytype(). Since st_geometrytype() isn't
> calling public.geometrytype(), it can't find the function in the current
> search path. At least, this is what I think the issue is.
> The only way for me to get around this as things are now would be to
> edit the restore script so that it uses 'public' for the search path,
> then rewrite all the create index statements to refer to schema.table.
> Mike
> postgis-users mailing list
