[postgis-users] performace question
Martin Landa
landa.martin at gmail.com
Wed Apr 1 11:06:54 PDT 2009
2009/4/1 Paul Ramsey <pramsey at opengeo.org>:
> Can you share your data with me? I'm interested to profile and see
> where the bottleneck actually is.
data are available at
http://josef.fsv.cvut.cz/~landa/postgis/obce_cr.sql.gz
before import define also local SRS
INSERT INTO spatial_ref_sys VALUES (102067, 'local', 102067,
'PROJCS["Krovak",GEOGCS["bessel",DATUM["unknown",
SPHEROID["Bessel_1841",6377397.155,299.1528128],
TOWGS84[570.8,85.7,462.8,4.998,1.587,5.261,3.56]],
PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433]],
PROJECTION["Krovak"],PARAMETER["latitude_of_center",0],
PARAMETER["longitude_of_center",0],PARAMETER["azimuth",0],
PARAMETER["pseudo_standard_parallel_1",0],PARAMETER["scale_factor",1],
PARAMETER["false_easting",0],PARAMETER["false_northing",0],UNIT["meter",1]]',
'+proj=krovak +a=6377397.155 +rf=299.1528128 +no_defs
+towgs84=570.8,85.7,462.8,4.998,1.587,5.261,3.56 +to_meter=1.0');
Thanks in advance, Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
