[postgis-users] Error using PostGIS and GEOM
Giri giriprakash at gmail.com
Fri Apr 3 09:32:20 PDT 2009
HI Kevin,
Sorry for this delayed response, when I tried the query, I am getting the
following error:
processdb=# select public.extent('POINT(0 0)');
ERROR:  function public.extent("unknown") does not exist
HINT:  No function matches the given name and argument types. You may need
to add explicit type casts.
any idea?
Thanks!
Giri
On Mon, Mar 2, 2009 at 12:43 PM, Kevin Neufeld <kneufeld at refractions.net>wrote:
> Just a random thought here.  Did you accidentally install PostGIS in a
> schema other than public?   If so, is that schema on the search_path of the
> user you are using to connect within GeoServer?
> Do you get the same answer when you do this from psql or PgAdminIII?
> postgis=# select public.extent('POINT(0 0)');
>    extent
>  BOX(0 0,0 0)
> (1 row)
> Cheers,
> Kevin
> Giri wrote:
>> Hi Mark,
>> I am using the latest stable versions of Geoserver and PostGIS, the
>> installation looks good, no errors were reported.
>> Thanks!
>> Giri
>> On Fri, Feb 27, 2009 at 10:11 AM, Mark Cave-Ayland <
>> mark.cave-ayland at siriusit.co.uk <mailto:mark.cave-ayland at siriusit.co.uk>>
>> wrote:
>>    Giri wrote:
>>        Thanks for the response, mmm I am using Geoserver (version1.7.2)
>>        , and when I try to create the featureType "polygon", it is
>>        complaining about
>>        class org.postgresql.util.PSQLException: ERROR: function
>>        extent(geometry) does not exist
>>        shouldn't PostGIS  have some backword support for the extent
>>        function?
>>        thanks!
>>        Giri
>>    Hi Giri,
>>    There has been talk of removing the old non-ST prefix functions from
>>    PostGIS, but so far this hasn't happened. Perhaps you need to check
>>    your installation?
>>    HTH,
>>    Mark.
>>    --    Mark Cave-Ayland - Senior Technical Architect
>>    PostgreSQL - PostGIS
>>    Sirius Corporation plc - control through freedom
>>    http://www.siriusit.co.uk
>>    t: +44 870 608 0063
>>    _______________________________________________
>>    postgis-users mailing list
>>    postgis-users at postgis.refractions.net
>>    <mailto:postgis-users at postgis.refractions.net>
>>    http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090403/c6e78bc8/attachment.html>
