[postgis-users] "Query failed: ERROR: invalid byte sequence forencoding"
Paragon Corporation lr at pcorp.us
Sun Apr 5 14:38:41 PDT 2009
Are you running the shp2pgsql with the -W latin1  switch?  (where latin1 can
be replaced with an alternative encoding but hta toone usually works in most
cases)
That usually fixes these kinds of issues.
Leo
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of yoda2nd
Sent: Sunday, April 05, 2009 5:28 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] "Query failed: ERROR: invalid byte sequence
forencoding"
Hello,
I have been beating my head on the wall for several days now trying to
figure out how to fix this issue.  I am trying to import several large
shapefiles into PostGIS using shp2pgsql, however I keep getting the
following error:
psql:shapefile.sql:133787: ERROR:  invalid byte sequence for encoding
"UTF8": 0xa8
HINT:  This error can also happen if the byte sequence does not match the
encoding expected by the server, which is controlled by "client_encoding".
The database is set to UTF8 and a search on google has not turned up much.
The DB server is running on Win2k.
I am rather stumped since I have no idea if this is an issue on the server
side, with the shapefile or with shp2pgsql.
I have no idea how to solve this and was wondering if someone would be
gracious enough to nudge me in the right direction here?
Many thanks in advance.
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
