[postgis-users] Shp2Pgsql - how to handle carriage returns ?
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Fri Apr 10 01:32:11 PDT 2009
Dave Fuhry wrote:
> I use the attached patch, which tweaks shp2pgsql to handle newlines
> (\n) and carriage returns (\r), replaces hi-bit characters with a
> question mark, and removes some geometry checks.
> You probably only want to do the first of those three. In that case,
> the patch should be easy to modify. Hope you find it helpful.
> -Dave
Yeah, the escaping part was a bug in shp2pgsql - the rules for escaping
COPY sequences were wrong. I've just applied a modified escaping patch
to SVN which removes the E'...' notation and now uses the correct
escaping for both COPY and INSERT modes.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
