[postgis-users] Finding points in a circle
nicklas.aven at jordogskog.no
Tue Apr 14 01:37:19 PDT 2009
Hi Simon
I'm afraid I don't really get your question.
But, what I ment was that he should have a colun with the individual radius for each row. He described that the radius could be different for each "circle", so I guess he have to supplie the radius for each row.
Then the st_dwithin-function will check if the random point is within the radius (taken from the radius-column) from the random-point.
/Nicklas
2009-04-14 Simon Greener wrote:
Niklas,
>What values for theradius do you give st_dwithin given that you don't know the values of the radius value in the table? What if you supply a radius of 1,000KM and there happens to be a point outside this whose radius is 1,500KM?
>regards
>SImon
>> Hi
>> No you don't have to make a circle first. One way is to just do a radius search from your point with the given radius.
>> If you have one column with latitude and one with longitude and one with radius then this should work
>> select * from thetable where st_dwithin(randompoint,ST_MakePoint(theLongitud, theLatitud), theradius);
>> The query might get slow if you have a big table as you descibed.
>> Then it might be a good idea to create a geometry column and store the latlongs as points.
>> SELECT AddGeometryColumn( 'public', 'thetable', 'thepoint_lonlat', 4269, 'POINT', 2 );
>> The above code will create a geometry column named thepoint_longlat in the table zctas that validates to make sure the inputs are 2-dimensional points in SRID 4269 (NAD83 longlat).
>> the above is copied from www.bostongis.org
>> and then fill thegeometry with data like:
>> update thetable setthepoint_lonlat= st_makepoint(ST_MakePoint(theLongitud, theLatitud))
>> then you can make a gist-index on the column.
>> and I think in your case it could work with making a gist index like
>> create index idx_lat_long_radius
>> on thetable
>> using gist(st_buffer(thepoint_lonlat, theradius))
>> then you should get boundingboxes stored for each point/radius-circle
>> Then you can run the above query:
>> select * from thetable where st_dwithin(randompoint,thepoint_lonlat, theradius);
>> I'm not good in indexes, but I think this will be a fast solution.
>> /Nicklas
>> 2009-04-14 Tony Elmore wrote:
>> Admittedly, I have not spent a tremendous amount of time with this yet
>>>- so I'm not really asking for a solution here, but would like some
>>>feedback to determine if I'm on the right track.
>>>Is this scenario possible using postGIS?
>>>i have many items (hundreds of thousands) with each item containing a
>>>lat / lng and a radius (each item could have a different radius). The
>>>circle created by the lat / lng and radius for each item would in all
>>>likelihood overlap with other items.
>>>Given a random point, is it possible to retrieve all of the rows where
>>>the random point is inside the circle created from the lat / lng and
>>>radius?
>>>I would assume I should create the circle for each item first and
>>>store that as geometry.
>>>Could someone please verify that this scenario is appropriate for
>>>postgis.
>>>Regards,
>>>Tony
>>>_______________________________________________
>>>postgis-users mailing list
>>>postgis-users at postgis.refractions.net
>>>http://postgis.refractions.net/mailman/listinfo/postgis-users
>SpatialDB Advice and Design, Solutions Architecture and Programming,
>Oracle Database 10g Administrator Certified Associate; Oracle Database 10g SQL Certified Professional
>Oracle Spatial, SQL Server, PostGIS, MySQL, ArcSDE, Manifold GIS, FME, Radius Topology and Studio Specialist.
>39 Cliff View Drive, Allens Rivulet, 7150, Tasmania, Australia.
>Website: www.spatialdbadvisor.com
> Email: simon at spatialdbadvisor.com
> Voice: +613 9016 3910
>Mobile: +61 418 396391
>Skype: sggreener
>Longitude: 147.20515 (147° 12' 18" E)
>Latitude: -43.01530 (43° 00' 55" S)
>NAC:W80CK 7SWP3
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090414/ee267540/attachment.html>
