[postgis-users] Install Posgrelsql 8.0.3 on Windows XP PRO
Obe, Regina
robe.dnd at cityofboston.gov
Tue Apr 14 05:28:42 PDT 2009
I'm sure there is a very good reason you are using the antiquated 8.0.3.
Just curious what is that reason?
I'm guessing you forgot to install plpgsql language in your database.
createlang plpgsql SIG
then run the .sql files.
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
patxi.mayol at free.fr
Sent: Tuesday, April 14, 2009 8:20 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Install Posgrelsql 8.0.3 on Windows XP PRO
I have install postgresql 8.0.3 with no problem;
I want now try to install gis database : i use command on DOS like this
C:\postgresql>createdb SIG --> it is OK
C:\postgresql>psql -d SIG -f D:\postgresql\share\contrib\lwpostgis.sql
--> i have this message :
psql:D:/postgresql/share/contrib/lwpostgis.sql:48: ERROR: type
"histogram2d" already exists
psql:D:/postgresql/share/contrib/lwpostgis.sql:65: ERROR: current
transaction is aborted, commands ignored until end of transaction block
psql:D:/postgresql/share/contrib/lwpostgis.sql:70: ERROR: current
Have you an idea ?
thanks
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
