[postgis-users] error installing postgis 1.3.5 with postgres 8.0/rhel5
Shad Keene
shadkeene at hotmail.com
Thu Apr 16 09:31:09 PDT 2009
Can anyone help with the following errors? My IT person is doing an install of postgis 1.3.5 on a rhel5 machine with postgresql 8.0 already installed(came with rhel5). I already tested postgresql and the database is working.
Here's the lengthy error code. And I have some more error code that I've attached that my IT person sent me. Does anyone have ideas on why this is not installing properly? Thanks!!
required c++ compiler to be installed so I did that.
Now configure process gets further but is still bombing out.
[root at zoa-project postgis-1.3.5]# ./configure
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for g++... no
checking for c++... no
checking for gpp... no
checking for aCC... no
checking for CC... no
checking for cxx... no
checking for cc++... no
checking for cl.exe... no
checking for FCC... no
checking for KCC... no
checking for RCC... no
checking for xlC_r... no
checking for xlC... no
checking whether we are using the GNU C++ compiler... no
checking whether g++ accepts -g... no
checking whether ln -s works... yes
checking for iconv_open in -liconv... no
checking for libiconv_open in -liconv... no
checking for iconv_open in -lc... yes
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking iconv.h usability... yes
checking iconv.h presence... yes
checking for iconv.h... yes
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for pg_config... no
configure: error: PostgreSQL is required by PostGIS
_________________________________________________________________
Rediscover Hotmail®: Get quick friend updates right in your inbox.
http://windowslive.com/RediscoverHotmail?ocid=TXT_TAGLM_WL_HM_Rediscover_Updates2_042009
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090416/19d14fd2/attachment.html>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090416/19d14fd2/attachment.txt>
