[postgis-users] performace question
Martin Landa
landa.martin at gmail.com
Thu Apr 16 15:45:01 PDT 2009
2009/4/1 Paul Ramsey <pramsey at opengeo.org>:
> You could also make it faster by cutting your boundary line up into
> about 200 smaller lines. That way your indexes would be useful and
> most of the candidates would be rejected right away on bounding box
> criteria, instead of falling through to full geometry tests.
thanks for help.
Probably I do not understand ST_Touches() correctly.
1) create boundary of CZ based on cities ('obce').
CREATE TABLE cr (gid serial);
ALTER TABLE cr ADD PRIMARY KEY (gid);
SELECT AddGeometryColumn('cr', 'the_geom', 102067, 'LINESTRING', 2);
INSERT INTO cr VALUES (1, (SELECT ST_Boundary(ST_Union(the_geom))
AS the_geom FROM obce GROUP BY pomoc));
CREATE INDEX cr_the_geom_gist ON cr USING GIST (the_geom);
2) select all cities which touch the state boundary
SELECT count(obce.gid) FROM obce,cr WHERE ST_Touches(obce.the_geom,
cr.the_geom);
-> 285 cities selected (OK)
OK, it takes more then 300s because the boundary is represented by one
linestring.
3) split the boundary to 2km length linestrings.
CREATE TABLE cr_2km AS SELECT ST_Line_Substring(the_geom, 2000 * n / length,
CASE
WHEN 2000 * (n + 1) < length THEN 2000 * (n + 1) / length
ELSE 1
END) AS the_geom
FROM
(SELECT cr.gid,
ST_LineMerge(cr.the_geom) AS the_geom,
ST_Length(cr.the_geom) AS length
FROM cr
) AS t
CROSS JOIN generate_series(0, 2000) AS n
WHERE n * 2000 / length < 1;
ALTER TABLE cr_2km ADD COLUMN gid serial;
ALTER TABLE cr_2km ADD PRIMARY KEY (gid);
CREATE INDEX cr_2km_the_geom_gist ON cr_2km USING GIST (the_geom);
4) SELECT count(distinct obce.gid) FROM obce,cr_2km WHERE
ST_Touches(obce.the_geom, cr_2km.the_geom);
-> only 211 cities selected (BAD)
but
ST_Intersects(obce.the_geom, cr_2km.the_geom);
gives right answer.
Thanks for any hits, Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
