[postgis-users] error installing postgis 1.3.5 with postgres 8.0/rhel5
Devrim GÜNDÜZ devrim at gunduz.org
Fri Apr 17 21:46:07 PDT 2009
On Thu, 2009-04-16 at 14:33 -0700, Shad Keene wrote:
> configure: error: Can't find 'flex'
postgresql-devel, proj-devel, geos-devel, byacc, proj-devel, flex
These are the packages that you need to install before trying to compile
PostGIS. The command is:
yum install postgresql-devel proj-devel geos-devel byacc proj-devel flex
Alternatively, you can use PostgreSQL RPM Repository. I'm building
PostGIS against PG 8.0 on RHEL 5, too:
http://yum.pgsqlrpms.org
Regards,
Devrim GÜNDÜZ, RHCE
devrim~gunduz.org, devrim~PostgreSQL.org, devrim.gunduz~linux.org.tr
                   http://www.gunduz.org
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090418/d8888f57/attachment.pgp>
