[postgis-users] identfying a nearest point
Stephen Woodbridge woodbri at swoodbridge.com
Thu Apr 23 07:28:36 PDT 2009
Stephen Woodbridge wrote:
> Supunmali Ahangama wrote:
>> Please suggest me with the POSTGIS/pgrouting function to identify the
>> nearest
>> point from set of points (vertices in a graph) to a particular point
>> (outside the graph)?
> You typically want to search within some radius so you do not have to do
> a full table scan.
> select * from vertices_tmp where st_expand(setsrid(makepoint(x,y),4326))
> && the_geom order by distance(setsrid(makepoint(x,y),4326),the_geom) asc
> limit 1;
> Should do what you want.
> -Steve
Oops, forgot to put the raduis in:
st_expand(setsrid(makepoint(x,y),4326),radius)
limit 1;
-Steve
