[postgis-users] identfying a nearest point
Daniel Kastl
orkney at gmx.de
Fri Apr 24 01:19:59 PDT 2009
> This is the SQL I tried with:
> select v.*, c.gid
> from vertices_tmp v, customer_location c
> where c.gid=1 and
> st_expand(setsrid(((select the_geom from customer_location where
> gid=1)),4326), 10000000) && setsrid(v.the_geom,4326)
> order by distance(setsrid((select the_geom from customer_location where
> gid=1),4326),setsrid(v.the_geom,4326))
> asc limit 1;
Without having tested this "100000000" looks very suspicious.
This value is in the same projection as your geometry is set: 4326
4326 is in degree, so you could try it with 0.1 for example.
Daniel
