[postgis-users] identfying a nearest point
Supunmali Ahangama
supunmali7 at gmail.com
Fri Apr 24 04:31:57 PDT 2009
Daniel Kastl-2 wrote:
> Hi,
>> This is the SQL I tried with:
>> select v.*, c.gid
>> from vertices_tmp v, customer_location c
>> where c.gid=1 and
>> st_expand(setsrid(((select the_geom from customer_location where
>> gid=1)),4326), 10000000) && setsrid(v.the_geom,4326)
>> order by distance(setsrid((select the_geom from customer_location where
>> gid=1),4326),setsrid(v.the_geom,4326))
>> asc limit 1;
> Without having tested this "100000000" looks very suspicious.
> This value is in the same projection as your geometry is set: 4326
> 4326 is in degree, so you could try it with 0.1 for example.
> Daniel
> postgis-users mailing list
No, it does not work. It doesnt show anything when used 0.1 as radius.
and I tried this just considering distance (full table scan):
select v.*, c.gid
where c.gid=1
gid=1),4326),setsrid(v.the_geom,4326)) asc
limit 1;
This SQL do not consider the radius, it just consider the distance and scan
the table fully; but it still gives the same answer (which is incorrect).
Please provide me with some suggestions.
View this message in context: http://www.nabble.com/identfying-a-nearest-point-tp23193816p23214605.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
