[postgis-users] identfying a nearest point
Supunmali Ahangama supunmali7 at gmail.com
Fri Apr 24 09:23:19 PDT 2009
Stephen Woodbridge wrote:
> What is the response to the following queries:
> select full_postgis_version();
> select astext(the_geom) from customer_location where
>  > gid=1;
> select astext(the_geom) from vertices_tmp limit 1;
> -Steve
> postgis-users mailing list
Hi Steve,
select full_postgis_version(); is not working. But,
select postgis_version();
"1.3 USE_GEOS=1 USE_PROJ=1 USE_STATS=1"
select astext(the_geom) from customer_location where gid=1;
"POINT(-96.7396491708658 32.9772528902849)"
"POINT(2512160.45149086 7040141.09734678)"
View this message in context: http://www.nabble.com/identfying-a-nearest-point-tp23193816p23220034.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
