[postgis-users] Lambert72 to WGS84
Obe, Regina
robe.dnd at cityofboston.gov
Tue Apr 28 06:06:21 PDT 2009
Guy,
You would use the ST_Transform function. I see two Lambert 72 in my
database (31300 and 31370). I assume one of them is right for you, but
if not -- use http://spatialreference.org to find the right one
SELECT * FROM spatial_ref_sys where srtext ilike '%Lambert 72%'
WGS 84 has an SRID of 4326 so to transform a table you would do
something like
SELECT ST_Transform(the_geom, 4326)
FROM sometable
If you brought your data in with SRID = -1 or the wrong SRID, then you
would need to do
SELECT ST_Transform(ST_SetSRID(the_geom, 31300), 4326) As the_geom_wgs84
FROM sometable
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Guy
Thomas
Sent: Tuesday, April 28, 2009 8:39 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Lambert72 to WGS84
1. Which postGis methods do I use for converting Lambert72 coordinates
to WGS84 coordinates and vice-versa?
2. Does anybody know of a Java library that implements this conversion
or which I can use to implement it?
Guy Thomas guy.thomas at fks.be
fks bvba - Formal and Knowledge Systems http://www.fks.be/
Stationsstraat 108 Tel: ++32-(0)11-21 49 11
B-3570 ALKEN Fax: ++32-(0)11-22 04 19
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
