[postgis-users] selecting geometries, using 2 polygons
nicklas.aven at jordogskog.no
Tue Apr 28 06:37:12 PDT 2009
sorry strk, you are right
I was mixing symdifference with something else in my head.
Both should work
Sorry
/Nicklas
2009-04-28 strk wrote:
On Tue, Apr 28, 2009 at 03:16:04PM +0200, Malm Paul wrote:
>> Hi,
>> I have 2 polygons (rectangeles) p1 and p2, they intersect each other.
>> I would like to select all geometries within p1 excluding all geometries within p2.
>> How can I do this with postGIS and SQL ?
>I suggest you first get p3 as difference(p1, p2),
>then use ST_intersect on p3 and your geom column.
>You should be careful in the way you construct the query
>so that difference() is computed only once, and make sure
>the gist index is used by ST_intersect.
>--strk;
> Free GIS & Flash consultant/developer () ASCII Ribbon Campaign
> http://foo.keybit.net/~strk/services.html /\ Keep it simple!
>_______________________________________________
>postgis-users mailing list
>postgis-users at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090428/0d39b2f3/attachment.html>
