[postgis-users] Using routing to create polygons of estimated travel distances
Anton Patrushev
anton at orkney.co.jp
Thu Apr 30 22:14:35 PDT 2009
Hi Simon,
You can try to use Driving Distance function of pgRouting
(http://pgrouting.postlbs.org/wiki/DrivingDistance) - this is exactly
what you need.
Anton.
On Fri, May 1, 2009 at 1:57 PM, Simon O'Malley <simonom at gmail.com> wrote:
> Hi List
> Trying to get my head around the easiest way to generate a contour map of
> travel times from a central location based on road centreline network.
> We have a central location and need to generate polygons showing which
> properties are with 5, 10, 15 etc minutes of this location.
> A road network is present with estimated speeds along each segment so we can
> calculate estimated travel time along each segment.
> How do we go about traversing the networking and creating points at say 5
> minute intervals, making sure we are travelling away from the central
> location.
> The idea was then to join up the points to create polygons and overlay over
> the property boundaries.
> Any ideas/help much appreciated.
> Simon
> postgis-users mailing list
