[postgis-users] Length of Bigint, Double and Text fields
Aigars V
aigarsv at gmail.com
Wed Dec 2 00:58:35 PST 2009
http://mixed.dans.knaw.nl/files/TI838D.txt
2009/12/1 Gerald Creager <gerry.creager at tamu.edu>
> My experience in the past (including some .dbf imports by several systems,
> including legaccy dBase IV, was that in fact, these are dB-IV .dbf's. The
> difference is small, as noted below, between v. III and v. IV.
> gerry
> Peter Hopfgartner wrote:
>> Chris Hermansen wrote:
>>> Peter;
>>> The canonical description of DBase files seems to be
>>> http://www.clicketyclick.dk/databases/xbase/format/
>> Well, first of all, I do not know which dBase version is targeted by
>> ArcGIS.
>> Second, I doubt the exact values in
>> http://www.clicketyclick.dk/databases/xbase/format/data_types.html#DATA_TYPES.
>> From our tests, both dbase III and dBase IV can handle text fields <= 254
>> characters (and not < 254).
>> Further, dBase III can handle numerics with <= 19 digits and not < 18
>> digits. dBase IV limits this to <= 20 digits.
>> The above mentioned tool identifies ArcGIS generated files as dBase IV, in
>> clear conflict on what is said in the above mentioned Wikipedia article.
>> Cheers,
>> Peter
>>> On Tue, 2009-12-01 at 17:28 +0100, Peter Hopfgartner wrote:
>>>>>> Dear PostGIS devels,
>>>>>> since we right in the middle of comparing interoperability of shape
>>>>>> files between some FOSS programs and ArcGIS, we encoutered also the
>>>>>> following:
>>>>>> gvSIG chokes on the Bigint as produced by pgsql2shp. Looking at ArcGIs
>>>>>> generated files, the max length for numbers is 19, compared to 20 for
>>>>>> integers and 32 for floating points as in pgsql2shp. This seems to be
>>>>>> confirmed by some Borland tools, when configured for dBase III+.
>>>>>> Another limit seems to be that of text fields, that must be no longer
>>>>>> then 254. This is the maximum as given by ArcGIS and by the Borland tool.
>>>>>> Another point is Boolean: ArcGIS seems to not allow the creation of
>>>>>> boolean fields and the Borland Tool ("Database Desktop") says that Booleans
>>>>>> have a length of 1.
>>>>>> Regards,
>>>>>> Peter
>>>>> Hi Peter,
>>>>> You've brought up some interesting points here. Can you actually
>>>>> clarify these changes with regard to parts of the official shapefile spec,
>>>>> or have they been found purely through experimentation?
>>>>> ATB,
>>>>> Mark.
>>>> Hi Mark,
>>>> I do still have to figure out, if there are public specs for this. All
>>>> I've found is, that attributes should be in data base files which are in
>>>> dBase format (
>>>> http://www.esri.com/library/whitepapers/pdfs/shapefile.pdf). From the
>>>> analysis of the file (and Wikipedia:
>>>> http://en.wikipedia.org/wiki/Shapefile), it seems that this should be
>>>> dBase III. I do not have any evidence that there is a public spec for dBase
>>>> III.
>>>> So all we did is basically gather some experimental data, where ArcGIS
>>>> and gvSIG are our references. The first, because ESRI introduced the shape
>>>> file format and gvSIG, because it is the desktop environment that we
>>>> encourage our customers to use. Anyway, we have an old Borland/Inprise tool
>>>> ("Database Desktop") here for managing dBase files and used it for our
>>>> tests.
>>>> Peter
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20091202/fd0157f5/attachment.html>
