[postgis-users] problems with UPDATE
Daniel Grum
daniel.grum at unibw.de
Fri Dec 4 04:39:59 PST 2009
Hi
I want to update a geometry table with polygon geometries:
UPDATE wald_by
SET the_geom =
ST_BuildArea(ST_Collect(ST_Intersection(poly.the_geom,ST_Expand(pt.the_geom,
2000)),poly.the_geom))
FROM public.wald_by poly, public.holzfaeller pt, public.runden i
WHERE poly.the_geom && ST_Expand(pt.the_geom, 2000) AND pt.style=2 AND
i%10=0;
Every 10th round this Update will be startet and only for this that have
the style=2 -->lumberjacks that clear wood and not work regenerative
like style=1.
Info to the attributes of the table:
gid serial NOT NULL, id integer, the_geom geometry, flaeche double
precision, flaeche_ges double precision,
CONSTRAINT wald_by_pkey PRIMARY KEY (gid),
CONSTRAINT enforce_dims_the_geom CHECK (ndims(the_geom) = 2),
CONSTRAINT enforce_geotype_the_geom CHECK (geometrytype(the_geom) =
'MULTIPOLYGON'::text OR the_geom IS NULL),
CONSTRAINT enforce_srid_the_geom CHECK (srid(the_geom) = 31467)
The Update don't works because:
ERROR: new line for relation »wald_by« breaches Check-Constraint
»enforce_geotype_the_geom«
So I thing the new geometry is no MULTIPOLYGON???!!!
Are there any ideas?
--daniel
