[postgis-users] st_union and simple line merge
Paul Ramsey pramsey at cleverelephant.ca
Fri Dec 4 08:26:49 PST 2009
ST_LineMerge dissolves linestrings the way you want... We're
inheriting the semantics of Union from JTS. It's possible that we
should be delegating to linemerge in line/line cases. That would be a
big behavior change, however.
P
On Fri, Dec 4, 2009 at 6:13 AM, Nicklas Avén <nicklas.aven at jordogskog.no> wrote:
> Hallo
> I found that st_union makes no effort to avoid multilinestring from
> st_union(linestring, linestring)
> Is this expected?
> an example:
> select st_astext(st_union('LINESTRING(1 1, 5 5)'::geometry, 'LINESTRING(5 5,
> 10 5)'::geometry));
> returns MULTILINESTRING((1 1,5 5),(5 5,10 5))
> and worst for practical cases if we input the linestrings in opposite order
> select st_astext(st_union( 'LINESTRING(5 5, 10 5)'::geometry, 'LINESTRING(1
> 1, 5 5)'::geometry));
> we get:
> "MULTILINESTRING((5 5,10 5),(1 1,5 5))"
> This is not described in the documentation but it says that st_union will
> try to dissolv boudaries, and I can't imagine any simplier case to dissolv
> boundaries than this.
> Is this the expected bahavior, is there any other way to merge simple
> linestrings to new linestrings?
> Thanks
> Nicklas
> postgis-users mailing list
