[postgis-users] shp2pgsql
pcreso at pcreso.com pcreso at pcreso.com
Thu Dec 10 07:54:18 PST 2009
On a linux platform you can use:
shp2pgsql -a [...] | sed 's/text/klassen/g' | psql -d <database>
under Windows you can run shp2pgsql -a [...] > file.sql
then edit file.sql & do a search/replace on "text" to "klassen"
then run psql -d <database> -f file.sql
Always assuming the word "text" is only ever used as the column name.
If this is not the case, then you will need to edit the file & check each search/replace occurrence.
Or you can use a temporary table (tab2) to insert the data into using shp2pgsql, then in your database run:
insert into tab1 select * from tab2;
drop table tab2;
HTH,
  Brent Wood
--- On Thu, 12/10/09, MisterX <helpmisterx at googlemail.com> wrote:
> From: MisterX <helpmisterx at googlemail.com>
> Subject: [postgis-users] shp2pgsql
> To: postgis-users at postgis.refractions.net
> Date: Thursday, December 10, 2009, 10:23 PM
> Hi,
> my problem is, that i have a database table with two
> columns with the name klassen ant the_geom. In my shapefile
> the columns called text and the_geom. Now I want to append
> the shapefile on the database table, but how can I tell the
> shapeloader that the column text affiliate to the colum
> klassen?
> shapefile                     database
> Table
> --> text                    --> klassen
> --> the_geom                --> the_geom
> Can anybody help me with this problem?
> Thank you very much.
> MisterX
> -----Inline Attachment Follows-----
> postgis-users mailing list
