[postgis-users] Error
    Kevin Neufeld
    kneufeld at refractions.net
    Fri Dec 11 22:41:11 PST 2009
How did you define deviceid?  It must be of type "record".
-- Kevin
Bob Pawley wrote:
> I recieved an error which I don't understand.
> Would it be possible for someone to translate it?
> ERROR:  loop variable of loop over rows must be a record or row
> variable or list of scalar variables at or near "Loop"
> Here is the function that leads into the loop, if of any help.
> For deviceid In Select devices_id
>  from p_id.processes, p_id.p_id, processes_count, p_id.devices
>  where p_id.processes.ip_op_equipment = 'op'
>  and p_id.processes.process_id = p_id.p_id.process_id
>  and p_id.processes.pump1 = 'True'
>  and p_id.processes.p_id_id = processes_count.p_id_id
> -- and p_id.devices.fluid_id = fluidid2
>  order by p_id.processes.process_id desc,
>  p_id.devices.devices_id asc
>  Loop
> Thanks
> Bob
> postgis-users mailing list
