[postgis-users] Weird GEOS problem
João Gonçalves
joaofgo at gmail.com
Tue Dec 15 12:16:41 PST 2009
Yes, the connection resource object goes invalid and I need to create a
new one. I've also experienced server shut downs caused by this problem.
Funny, I added eactly the same solution drop and reconnect within a
tryCatch block. I'm guessing this is a server side/GEOS issue because it
tends to happen in very specific conditions, in my case when
geoproccessing is very intensive. Nevertheless, I have no real knowledge
on GEOS internals to figure this out.
> Did you also see that the connection is no longer valid from that
> point on and you need to re-connect? I mean, even if you wait and try
> again, it won't work. I have to resort in restarting the app but not I
> added code to try to drop and re-connect. Haven't hit the prob yet to
> confirm this solves it.
> *From:* postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] *On Behalf Of
> *"Joao G."
> *Sent:* Sunday, December 13, 2009 11:18 PM
> *To:* PostGIS Users Discussion
> *Subject:* [postgis-users] Weird GEOS problem
> I also found this problem when issuing many queries per minute or when
> performing multiple/time demanding distance calculations between
> complex (multi)geometries. I use XP pro with R (RPostgreSQL lib) to
> connect to PostgreSQL.
> George Vlahakis escreveu:
> Ok thanks, I used to use npgsql but for spatial queries and binary
> geometry retrieval I found it the opposite. It has been some time, but
> I will try it.
> <mailto:postgis-users-bounces at postgis.refractions.net>
> *Emilie Laffray
> *Sent:* Friday, December 11, 2009 1:13 PM
> *Subject:* Re: [postgis-users] Weird GEOS problem
> 2009/12/11 George Vlahakis <g.vlahakis at telenavis.com
> <mailto:g.vlahakis at telenavis.com>>
> Hi all,
> Probably nobody has seen this, but on a particular machine (Win XP)
> every 2-3 hours or so I am getting the following error:
> System.Data.Odbc.OdbcException: ERROR [XX000] ERROR: Error creating
> GEOS Coordinate Sequence; Error while executing the query
> I might be wrong but you are using .NET?
> If it is indeed the case, I would suggest dropping the use of odbc,
> and use npgsql which provides a direct connection to the database. It
> should give you better performance, and maybe extra stability.
> Emilie Laffray
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20091215/3341f6a1/attachment.html>
