[postgis-users] template_postgis14
Gilles Bassière
gilles.bassiere at makina-corpus.com
Wed Dec 16 08:14:02 PST 2009
Mark Vantzelfde wrote:
> I am missing template template_postgis14 in my database server on a
> linux system. Both template0 and template1 are there. How do I go about
> installing template_postgis14?
> Thanks
> Mark
Mark,
The Windows installer indeed set up a postgis template for you. Please
note that this installer is a 3rd-party software. With the basic Postgis
installation, you have to load Postgis in your database manually. The
official documentation explain this:
http://postgis.refractions.net/docs/ch02.html#id2532099
(It is usually advised to read the documentation before asking the list).
If you really want this template, you can create it using normal SQL.
This post might help:
http://geospatial.nomad-labs.com/2007/12/16/template-postgis-database/
It's a bit old but not outdated as far as I know (except filenames which
has been renamed in 1.4).
Hope it helps
Gilles Bassière - MAKINA CORPUS
http://www.makina-corpus.com
